Greetings mzac!
I did some fishing for answers to your questions, so here goes :
1. The Helix Gateway does not have battery backup, but telephone service is not integrated with Helix anyway, so, Helix customers who also have the Residential Telephony service will have the Arris modem still installed to provide the Telephony service.
2. Bridge mode for all intents and purposes disables the "router" portion of the Gateway. Your router will be given a public IP address and all LAN and Wi-Fi functions will be handled by your router. No Double-NAT needed in that mode.
3. Native IPv6 is not currently available on Helix for the time being with the Helix service. It will be enabled in a future update. Bridge mode will have no influence on IPv6. If your router supports native IPv6, once it's enabled on the Helix network, it will be work natively in Bridge mode or not.
4. The auto-installation kit provided either in retail stores or by delivery includes all necessary equipmen to install the Helix service while keeping the Telephony service, including the safety removal tool, a cable splitter and an additional cable segment.
5. Safety sleeves are no longer installed or required, but older installations may still have them.
7. Helix plans require the Helix service and equipment. However, your current modem will still be able to provide the Telephony Service.
8. The maximum upload speed provided with the Helix 100 plan is 30 Mbps,
I hope this helps!
-JFrancoisD
